I was looking at a winter tires and there is a significant difference in the price for the 16" and the 15" tires. So I was wondering if anyone had thought about putting a set of 15's on for the winter tires....
Thanks,
Jim
The truth is, you can put any size wheels you want on the car as long as the overall diameter of the wheel/tire set is the same. Use this chart to determine what size you need to run w/o triggering an ABS light, traction control light or severly degrading the accuracy of the speedometer.
http://www.miata.net/garage/tirecalc.html
Just enter your current size and the size you want to go to and it will give you the difference in overall diameter.
and they clear the discs of the brakes, and the bolt pattern and offset match (or you have hub adaptors / wobble bolts
