irishmcsaab said:
Are there really two sensors for that engine?
No, that sounds like a misunderstanding. There is a
crank-shaft position sensor and a separate
cam-shaft position sensor
I have the 4-cyl engine, but the same Saab EPC (electronic parts catalog) list parts for the V6. Here are the Saab part numbers:
Article : Crankshaft position sensor
PartNo : 4504288
Usage : 1994-1995, 6-CYL
Supplementary Description : crankshaft
Order Quantity : 1
Article : Camshaft position sensor
PartNo : 4770079
Supplementary Description : camshaft
Order Quantity : 1
The picture shows the sensors on the opposite side of the engine, the crankshaft sensor is at the flywheel end, and has a cable that wraps around the engine from front to back, where it plugs in.
