Hello,
Thank you for taking the time to read this post.
I am having one heck of a time trying to get my 1999 93 Turbo started.
Not too long ago I replaced the head gasket after severely overheating the engine. I put a straight edge across the head in all directions and it seemed to be fine. A .005" shim would not pass under the straight edge at all.
I got it started but it was difficult, I did really have to crank on it over and over and over !! Once it started and ran for a while it was fine. It would not idle smoothly until it ran for a five minutes or so
I have been checking my valve timing. I have a SAAB WIS (Workshop Information System) CD and the instructions are with #1 and #4 cylinders at TDC (Top Dead Center) to align the notches on the cams to the marking on the block head near the sprockets. I have heard the the HAYNES MANUAL makes this same instruction and some users within this forum recommend not to go by this instruction.
Does anyone know why ?
I went the "OLD SCHOOL" way and brought #1 up to TDC by hand and made sure the marks were aligned. I put the cams back to where the car was once running and I still can not get it to fire up.
Before all this I did move the cam closest to the radiator because it looked to be off by just one tooth on the sprocket, when I started it, it sounded like marbles bouncing around inside the engine, I am thinking I damaged the valves ;oops:
When I try to start the car now it sound like there is no compression what-so-ever. It sounds like a little cranking sewing machine
I have been working on cars for many years but this is the first time I ever got involved directly with exhaust and intake valves, especially on SAAB's.
Could someone tell me how to check for bent or bad valves ?
Any information will be appreciated. Thank you for your time.
Rick
Rick
