Remove the cover from the void space between the false bulkhead and the firewall (aka - the aquarium). Use a 5/16" nut driver and a 25 Torx bit. Also pull the wiper fluid hose off the underside of the fitting.
When the cover is off, the air filter housing can be seen. It is in the vestibule - on the RH side. To access the filter, undo the one fastener and lift the cover off.
Pull the filter element and clean/replace as necessary:
