cdaly said:
I'd be amazed if there was an aftermarket supplier for any of the C900 'vert's window seals. They're so specific to the car and hood that your best option is either a breaker or a Saab dealer. If you find a breaker with such seals, grab the lot. The roof front and side seals unbolt/unscrew and there may be some adhesive on the front corners, the door seals should come off with these push-the-pin-through-the-centre rivets and maybe some screws. Grab the window edge seals too since they're unique to the 'vert.
Re: being specific: exactly... And a breaker - do you really want used rubber? I guess it's better than if yours is missing or rotted away. But mine popped in half from the friction of the window winding up and rubbing against it. So I dropped $65 at the dealer today for a replacement, not knowing if a used piece would be on the verge of doing the same. Guess I should lube the one on the other side to reduce the frictional pull, well as the new when I get it on. Thought about replacing both, but at $65- each, eh - let's wait 'til the other one goes.
Regarding the rivet attachments... I also got new metal pop-rivets (from the dealer - 12 for $40 - ow!) for the rubber "curtain" that goes along the lower edge on the inside of each door. I had previously procured excellent condition rubber "curtains" from someone parting out their C900 'vert. Now I have all the bits and can make the replacement. BUT - I had no idea these were the real metal pop-rivets - thought they would be like the plastic ones holding various other bits on. Two questions:
1) What's an easy way to get the old ones out, without marring my car door?
2) Do I need a rivet gun to install the new ones? I know how they work, in theory - put the shorter side in the hole and the gun pulls the center piece out and flattens the thinger on the backside, making it stay in place... Could the same be accomplished using, say, vice-grips and a lot of yanking? Or will I hose it all up...?
Thanks again!
-daniel
