Probably a dumb question, but i have a 92 turbo and the antenna isn't going up. I don't hear the motor turning, and I have power to the red wire at the antenna all the time, and power to the green (signal?) wire when the radio is turned on. I have no motor movement (or attempted movement). Is there supposed to be a ground wire on this thing somewhere or is it just grounded through the mounting bolts?
I'm assuming the antenna motor (or internal wiring) is bad, but I bought the car used and it's always had this problem so I just wanted to verify there isn't a missing ground wire.
Thanks
Thanks
