Hi Guys,
I bought a brand new turbo bypass valve and fitted it the other day as old one was not holding vacuum which lead to hissing noise coming from the vacuum line leading from the manifold.
So it was a fairly painless process to swap out however now the car keeps stalling when at low revs. It seems to idle ok if you are at a stand still but drive and then put in the clutch or stop at the lights and it will die. I took the Bypass valve out again and had a look. It seems to be all well. I also tested it for holding vacuum, again all good. The hoses all seem good. I cant understand what it might be. Any suggestions?
Thanks.
Possible something didn't go back together correctly? Some hose clamp not tight? Something broke coming apart or going back together?
