When I first got Lars he had a starting problem, where you turned the key and just got a click, the previous owner said he thought the wire to the starter motor had come loose, so he tightened it and the problem went away. Now it has come back again :wall: So what do I do?? Where is the starter motor?? and where should the wire be?? I have only some spanners and a socket wrench so unable to do anything major. It is now to dark to remove the battery to put it on charge. Please help. The only other choice I have is to call out the RAC in the morning, and I need the car for Sunday night to go to work.
Andy
Look at the faqs in the tech section there is a good article about testing the starter and what wires go where and where the starter is located. helped me a lot
Well Lars is now fixed and back on the road, the problem was the battery cable to the starter motor had come loose.
