1 - 15 of 15 Posts
It appears mine is shot, so I'm trying to get the best deal I can. A new OEM one listed for a 9-5 SE 1999 is about $300+ from what I can see. Do the 9-5 4cyl and 9-3s use the same blower motor or is the blower motor used in the 9-5SE specific to that model? Thanks.
EDIT: Also, what are the odds the blower motor resistor is gone? Would that need to be replaced if I replace the blower motor?
I had mine replaced last summer, $300 is about right. However, check the phone book, if you can find someone that rewinds motors for the windshield wipers they can often do the blower motor also and would be around $50.
BrightSide said:
Here's the part number for the 1999 9-5SE V6 3.0L model: 5049085
I cant find anything with that number :eek:
FAN UNIT : Supercedes from: 5333539 OES 5049085 $382.86
I cant seem to cross match this with the 9-3, sorry ;oops:
when my blower motor went on my '99 9-5 i had to replace the resistor as well... although i'm one of the few people who has had to do that as far as i can tell from reading online etc
it came out around $900 for the blower motor ($500 parts/labor) and $350 for the resistor (used, parts/labor)
the resistor is around $400 new i think...
So if I took a multimeter to the connections on the blower motor and they registered correctly, I shouldn't need to replace the resistor correct?
Discussion Starter · #13 ·
I found a used blower motor on car-part.com. Great listing database for all the junkyards in the US. Saved almost $200. I'll probably be switching it out this week, I'll document my progress and hopefully put together a tutorial.
Excellent, thanks!;)
You might need a puller to get the wiper arms off. Apparently you need to be Superman to pull them off manually.:confused:
1 - 15 of 15 Posts
