fr4gm0nk3y said:
Point is it's not proportionate to the amount of boost youre pushing
If anything's identical between two cars with the same tune, it should be this "readout". You would expect differences in readouts with an actual mechanical boost gauge, but not on an electronic one that operates on lookup tables with set data for a particular engine load. So if Rip's requested boost is lower than my requested boost, what's the result? That's my point/question.
I can't imagine that Rip's actual boost would be exceeding what is being requested, since the ECU controls boost by comparing the requested with the measured.
I agree, if you were clever you could reprogram the ECU to scale up the signal to the electronic gauge so it max's out all the time, but we're not that clever - well at least I'm not.
EDIT: I'm making the assumption here that our tunes are completely identical.
