'97 9000 5 speed - Has worked fine for several years, kids car so I wasn't driving it recently, "won't go into reverse". Dad to the rescue. Lots of play in the stick shift, remove boot and find broken off reverse lock out tab (plastic riveted to aluminum). Shifter pivot ball loose, spring gone, shift lifts up an inch or so. Tranny works great in 1st thru 5th but I can't get it into reverse. Local shop says that's because the part that broke off makes it twist in just the right way to go into reverse and it can't be replicated with that piece broken. I removed center console and removed stick shift and broken shift tower. Moving shift rod end I can still only get it into 1-5, not R. I want to check that the tranny is good before I try to find and replace the broken aluminum and plastic housing. Does anyone know if I should be able to get it into R without having a good stick shift in the car? Anyone have similar issues? Do transmissions typically break in such a fashion? Any thoughts/suggestions appreciated.
Also, if you are parting out a late model 9000 with a 5 speed I might need a shifter mechanism. Thanks, Joe
