I have three broken rear inner fender studs. 9-5 dame Edna wagon. Without my looking does anyone know of the upper stud if I drilled it out goes into the cabin or is the fender well double walled. Thanks in advance for any ideas.
Thanks Mimi. I think I will use a “ rivnut” compressible 6.0x1.0 threaded insert ; drill appropriated hole. The struggle is using alloy inserts. But with adequate rust proof coating it should be okay. I thought of spot welding new threaded studs but that’s a lot of equipment to obtain. I post up what I finish up with. Cheers
