Yesterday, I rotated the tires on my '03 linear. This was the first time the wheels have been off the car (I know - I probably should have done this at least 10000 miles ago...) As I typically do for all my cars, I gave the lug bolts a shot of lithium grease before putting them back, just to ensure they will come off in the future.
While torquing down the bolts for the first wheel I find that the bolts don't feel like they're torquing down propery - they get tight, but I can still turn them (I'm using an 16" breaker bar, so I do have a bit of leverage). I work my way around the bolts, and it just doesn't feel right. I can continue to turn them past the point I think I should be able to. I'm pulling pretty hard, but not any more than when I'm torquing the lug nuts on my Porsche or truck (If I had to guess, maybee 120 or 130 ft-pounds) One of the bolts snapped. Luckilly, I was able to back the bolt out.
After this happened, I found the torque spec in the manual (80 ft-pounds) and torqued the remaining lug bolts to that (more or less)
It seems strange to me that the lug bolt broke with a relatively low torque. Are they purposely designed to give at a low force like that? Could the grease have caused a problem? Has this happened to anyone else?
