OK. Had my front brake rotors and pads replaced by the dealer about 5 weeks / 300 miles (of mostly city driving) ago. They squeaked since replacement, had abated somewhat but still quite noticible and occasionally very loud and very shrill.
Brought back to the dealer - they re-seated them but said SAAB doesn't guarantee their pads not to squeak.
Further, their re-check said most likely the calipers are out of spec allowing pads to move in the caliper, and the only solution may be caliper replacement.
How true is this statement? Is there nothing else that can be done? I don't mind an occasional squeak but right now they always squeak once below, say, 10 mph...
The other issue is a metallic rattle in my rear driver's brake, when traversing rough roads, that goes away when I apply the brakes. Dealer said the sliding caliper is loose - again - only solution is to replace the caliper.
Otherwise, the braking system seems to work fine, but noise when I drive, noise when I'm stopping - it's driving me nuts!
I'm not much of a wrencher, so if the two solutions are 1) for me to rip the calipers apart myself and fiddle with them, or 2) get new calipers installed, I'll opt for the latter - just let me know!
Thank you.
-Daniel
Thank you.
-Daniel
