1 - 11 of 11 Posts
When brake pedal switch is pressed hatchback brake bulbs fail to light. Otherwise the position bulbs light when position light button is Turner on. I´ ve tested the brake wiring, and there's voltage on cold side of pedal brake and handbrake.
Fix the melted connector on the L/R light.
There are many posts on how to 'improve taillight ground.'
Discussion Starter #6 (Edited)
Ok, thanks Jim. When tested with screwdriver electrical tester, the pedal brake´s hot wire bright light, unlike the handbrake's white wire that fade light. The handbrake white wire's voltage could also be low from a poor ground?
Handbrake is NOT connected to brake light.
Fix rear light ground and stop overthinking.
Discussion Starter #8
So handbrake white wire is just connected to the dashboard parking light? Has the white wire 12V, or lower volts?
There is nothing on the wire... the switch takes the circuit to ground when the handbrake is on, turning the light in the dash on.
Discussion Starter #10
I'm confused. There must be a potential difference. Which voltage should indicate the voltmeter :
on pedal red hot wire?
on handbrake white wire?
The hand brake is not related to the foot brake electrically.
The hand brake has a single switch which completes a circuit for the dash light. Positive comes from the ignition switch, ground comes from the chassis. The switch on the handbrake completes the ground.
The foot brake switch completes a circuit for the rear lights. Positive comes from the battery, ground from the chassis. The switch on the pedal completes the positive.
1 - 11 of 11 Posts
