In a few short miles, my brake pedal has started going close to the floor. It pumps up with no problem but seems a little spongy. Holds pressure forever once pumped. Takes 30 seconds or so to go soft with my foot off. Pedal gets a little softer when car is off but not to floor. Pumps as usual when off up to very hard. Starting car causes expected slight depression, maybe a little more than usual but not really noticeable
It’s not my abs issue - I pulled the connector and it did not help. Fluid is full. Main vacuum line looks fine (5 spd).
