I've been getting my "Brake light failure" light coming on for several weeks now but can't find a problem. I do know that when it comes on, the light is not working. However, most of the time it is working. I can't find a loose wire, connection or short anywhere. The bulb has been changed several times. Does anyone out there have a clue what the problem might be?
Regards
Marts
Assure that both sides have new bulbs, properly installed.
Perhaps one is in a little loose..It happened to me
Then check out the center 4 little bulbs...
i got the rear light failure msg today..but everything seems fine..what could it be? I checked..all the lights were fine..i'm not sure is the inner blocks are suppose to light up or not..the ones closer to the license plate...
Clean the bulb and bulb seating of corrosion and oxidation. The failure detection works on monitoring a diiference in current between the two bulbs. The resistance due to dirty contacts will show as a failure. Not uncommon.
HTH
