Since I own my 9-5 I get the BLF message each time I start my car (which I delete), and most times the Cruise Control won't work until I lift the brake pedal. Sometimes when I have the CC on and drive over rougher roads the CC goes off and needs to be reactivated after lifting the brake pedal. Note that the brake lights are working as they should, I had also treated the contact points and connectors after cleaning them with electrical spray. No error codes, no other brake or ABS warnings.
Is the brake light switch shot or does it need some adjusting (if possible)?
