Hello,
I'm prepping my 1996 900SE turbo for a quick cross country jaunt; the plan is to depart northwestern Oregon for central North Carolina. So, I checked my brake fluid and discovered it was a bit low....and there's a hose fitting on the bottom of the reservoir without a hose attached to it. I couldn't find a loose/unconnected hose, should there be one there? Or is this connection for a different model?
Thank you.
You must have an auto trans. That hose nipple would be connected to clutch master cylinder in a manual transmission car. Fluid level goes down as brake pads wear. When you install new pads the pistons get pushed back in which pushes fluid back into the master cylinder. Have a nice trip.
Actually I have a manual transmission, so I guess guesstimate means I'm missing the hose to the clutch (not brake?) master cylinder? I'd better get it fixed!
