Does anyone know the proper torque for the brake caliper guide pins? The WIS has conflicting torque values called out:
Under "brake disc, front wheel," the instructions call for application of Loctite 242 and a torque of 81 lb-ft
Under "brake pads, front wheel" the instructions do not call out Loctite at all, and the torque is 21 lb-ft
If I had to guess, I'd assume the lower torque value is correct given the thread size of the pins. Is the higher torque value actually for the caliper mount, and not the caliper guide pins?
