On my 2000 9-3 convertible with an automatic transmission, the vacuum line that runs from the intake manifold to the vacuum pump and tees to the brake booster, has a check valve in it. Where should the check valve be placed, between the manifold and tee or between the vacuum pump and tee? There is a direction arrow on the check valve, in what direction should it be pointing? Any diagrams showing this?
Thanks, again, for all your help.
