I've read there's 2 methods for removing the brake booster, 1 being remove the whole bracket and the other just move the master cylinder out of the way. However, it seems that cars 2002+ with ESP also need the ABS/ESP unit whatever removed as well
Considering I would also have to remove the ESP unit, is the method where you undo the bracket bolts easier in this case?
Anyone done the job before?
