I have a 9-5 wagon, too, and I agree, the floor on that car is rock solid compared to the NG900 and 9-3. I tried to shore up the floor on my NG900 a while back. I had a local plastic supplier cut a circular piece of plastic that fit inside the spare tire's rim, and was thick enough that it brought it up to the same height as the tire. That helped tremendously, but then I swapped out the original spare for a 16" when I upgraded to 308mm front brakes, and haven't had a new piece of plastic cut. I really should, though, since that helped so much. The other thing I did was to cut a piece of thin board to stiffen up the back of the floor behind the spare. The downside to that one was that it got soft and moldy after a couple of trunk leaks, and then I discovered that it had rubbed on the steel body, right through the paint, and was causing things to rust.
