1 - 7 of 7 Posts
With a TD-04 controlled by an Abbott ECU do you think I'm going to need a Forge wastegate actuator spring in the 20-25psi range? This will be on my soon to not 2.0lpt.
I dont know of anyone who has needed to upgrade the wastegate at all :confused:
The current turbo has no actuator; the Forge item is, so I've been advised by a Turbo workshop, cheaper than genuine.
No actuator
I get ya now. I don't know about the wastegate spring though, probably best to ask Abbott what they think. I don't know which stage you're going for, but an aero only runs 15 psi.
You just need stock preload so you can get base boost of .45-.55 bar In short go for the green spring. :)
How many other car communities have a parts supplier that'll jump in and help you out. :cheesy:
1 - 7 of 7 Posts
