I'm interested in purchsing a boost cotroller and am wondering if there will be
any long term durability problems?
Also, Is it worth adding a BOV? Or are the two mutually exclusive?
I do like the idea of more power, easy...
becaus eyou have a 2000, you have trionic 7 engine management, so you cant use a boost controller of any sort to raise peak boost pressure, nor can you run an atmospheric blowoff vlave. you can use a recirculating valve, however.
Search for smbc and posts by ricot83. Smbc's don't usually raise peak boost, but you can modify the way the boost comes on with the car. There is a lot of research you can do on the matter.
