I think a a bad miss due to bad spark would cause low boost and my stalling issue (if the sparks totally stopped), but I think I would also hear it. It would also explain my P1300 and P1105. That sounds like a bad DIC or ECU. I need to get a Tech2.It will affect boost, but not enough for his level of low boost.
But I too am more concerned about why. Bearing check needed.
I'll put my usual plug in for chinacardiags.com. About $300 shipped. $50 more with the case. Invaluable when you have one of these cars.I think a a bad miss due to bad spark would cause low boost and my stalling issue (if the sparks totally stopped), but I think I would also hear it. It would also explain my P1300 and P1105. That sounds like a bad DIC or ECU. I need to get a Tech2.
However I should get more boost than none with an a really poorly running engine with the waste gate hose totally disconnected. I don't hear any misses, it just feels anemic and has no boost.
If you put a feeler gauge between the very edge of the exhaust impeller vane and the housing, how much actual play do you measure? Also look for evidence that a vane ever hit the housing.Just got my used turbo, the impellor vanes all look good and I don't feel any endfloat. However, I'd guess there's a half a millimeter of side to side float. I imagine this would diminish with oil and certainly with some oil pressure. Does this sound okay?
I had thought I'd swap this out and then rebuild my old turbo or get it rebuilt.in a year or two. It looks nicer outside than my old turbo. The housing and fittings have a bit less corrosion
That's not bad.I couldn't feel any difference when I pushed the vane toward my 0.002" feeler guage but I could feel some extra resistance with my 0.025" feeler guage. I felt a similar or slightly less amount of resistance when I pushed the other way and pulled my 0.005" guage through, and a bit more of tug with my 0.006" guage, so I'm going to say there's about 0.003" (0.08 mm) total side to side. That's not as much as I'd thought.
You can run the BCPR7ES plugs. They are good for about 10 to 12 K. You can get four for about $10. You can also run the OG 9–3 spec PFR platinum plugs.They will last 50 to 60 K. They will cost about $50. So same long-term cost. A lot of us prefer the cheaper copper plugs because we want to be in there every year anyway. L O L.I didn't see any branding on my DIC, so I think it's a cheapo one. The plugs I had were NGK BCPR7ES. I think it should be NGK PFR7H-10.
Here's a picture of the underside of my Digital Ignition Cassette. I believe the NGK ones would say NGK on them somewhere.You can run the BCPR7ES plugs. They are good for about 10 to 12 K. You can get four for about $10. You can also run the OG 9–3 spec PFR platinum plugs.They will last 50 to 60 K. They will cost about $50. So same long-term cost. A lot of us prefer the cheaper copper plugs because we want to be in there every year anyway. L O L.
If your DIC is non-factory, then it's definitely suspect. The aftermarket ones have a bad reputation. See the other thread on what's a factory DIC now for more info.
Definitely aftermarket.Here's a picture of the underside of my Digital Ignition Cassette. I believe the NGK ones would say NGK on them somewhere.
I was going to revisit the boost testing on my OG 9-3 after I fix some of my non-SAABs. Shouldnt the PCV valve be able to handle the 13ish psi of full boost pressure? I haven't yet fitted a guage to my test cap, but it doesn't seem to build any pressure at all before I hear hissing from the throttle body area.I'm on my phone but I believe it's part #30 you are looking for. #21 is the wrong part for sure.
You definitely want to disconnect & block the PCV system.
