I'm going to look into the turbo, based on what I find there I may want to pressure test the system.
I've never done this before but based on some YouTube videos that I've watched I was planning to disconnect the snorkel from the air box and make a cap from PVC.to fit in it.
I'd then fit a Schrader valve in the cap and pump it up to 20 psi or so and see if I have any leaks. Are there any components that I should disconnect to prevent damaging?
I think some people run over 20 psi boost. I haven't found a max boost spec in the WSI, I guess it varies depending on octane, etc. I was thinking about 1 atmosphere (14.7 psi) would be normal? Base boost pressure is 6.5 psi.
