1 - 8 of 8 Posts
Suddenly the blower motor on my 9-7x isn't turning off.
I did some research and forum searching and found several threads about this happening to a 9-3. http://www.saabcentral.com/forums/showthread.php?t=286986
This thread helped in that I was able to pull the fuse and get the blower to stop...
However, the fuse was under the hood of my 9-7x and not in a panel on the driver side.
Before I go digging further into my car in the cold... I wanted to know if anyone know where the resistor is located.
On the 9-3, it is behind/under the glove box. If it is there, great! If anyone is familiar, I would appreciate your insight!
go get yourself a new blower motor resister...GM came out with a new design...you will have to cut and splice the new wires for it...had to do it to my 2008 arc a couple of months ago...
cost me around 100 bucks cnd and did the install myself....the resister is located under and ahead ofthe glove box if I remember correctly ...took me all of 15 minutes to do the job..visually the resister looked in ok condition but the updated resister has a 5 prong connector rather than the 3 prong with 2 wires coming off the resister...
hope this saves you a little headache...
Great DIY, Thanks. Got the part# for the resistor and why didn't you just replace the bad resistor with a direct fit part instead of doing surgery to install a different part?
updated harness with updated resister...id assume the old style was re-designed for good reason...
I'm just wondering what is your screename? Is it supposed to be islam? Mine is my middle initial and part of my last name.
nope its supposed to just be slam....i guess really it dot slam hahha
nothing really behind it besides a nickname I got in highschool when i wrestled....
1 - 8 of 8 Posts
