Are the 900 and 9-3 rear shocks interchangeable?
I noticed the part numbers are different between the 900 and 9-3 on every shock except the Koni Yellow so I'm rather lost on whether this will work or not.
Thanks!
BTW, I'm sorry for posting what has likely been asked dozens (if not hundreds) of times. I can't seem to get this search function to work for me and TireRack's part numbers suggested both answers.
What are you trying to do?
They are interchangeable, though the 9-3 shock may be a bit stiffer due to more weight in the rear. When it comes to the Koni, I'm thinking it doesn't matter due to the performance stiffness of the shock.
Part numbers are different for OE shocks due to the different OE spring rates with particular models. The mounting is the same so aftermarket shocks like Koni are interchangable.
