1 - 8 of 8 Posts
Yes it would fit - no you dont need it, nor will you get any gains at this stage, wait till you are over 250 bhp (and even then I bet you wont notice it) ;)
Or as the mighty Kermit once wrote:
Kermit said:
So you're happy with your 9-5 but would like a bit more poke from the engine, how do you do it?
SAAB's Trionic 7 engine management system is a very complicated beast and tuning it is a speciality job, you cannot just put an Ebay transistor in and get another 20bhp. Dropping the car off at a standard tuning shop is a no-no as well, they are used to tweaking Bosch based systems not the Trionic system that SAAB employ.
Generally speaking the tuning of SAAB's is done on a "stage" basis.
Stage 1. Remapped ecu (and red injectors if you have green injectors fitted), also a drop in performance air filter
Stage 2. As stage 1 but with the addition of a free flow exhaust
Stage 3. As stage 2 but with a 3" downpipe with a fast road or race cat fitted, ecu remapped to cope with extra air flow (some tuners will use an uprated 3.5bar FPR)
Stage 4. As stage 3 but usually with a better intercooler, either in the standard place ala Abbott or a custom FMIC. Larger air delivery pipes, induction pipes are also options to be considered. 3" straight through exhaust is desirable, ecu remapped again
Stage 4+. These are custom remaps done specifically for the hardware that doesn't fall into the above category...e.g bigger turbo's, bigger fuel injectors, custom manifolds etc
Sticking with one tuning company will reap dividends because they will generally offer discounted prices for remaps as you go up the tuning stages.
The above stages are applicable to all the inline 4 cylinder engines, but please note you will get better results horsepower wise from the lower tuned lpt models. The Aero (HOT) models are pretty much tuned to the max and respond better to the early stage 1&2 tunes, after that they will need additional cooling or you will lose any extra performance to heatsoak very quickly.
Tuning options on the V6 is very limited, there is only one tuner offering a stage 1 upgrade for the V6 and thats Nordic. If you are looking to tune your 9-5 you need the 4 cylinder model.
Here are some useful links to manufacturers that provide tuning services for the 9-5.
http://www.maptun.com/
http://www.nordictuning.com/main.php?lang=en
http://www.genuinesaab.com (Provides Nordic in the USA)
http://www.abbottracing.com/
http://www.partsforsaabs.com/default.php?cPath=28_270
http://www.hirsch-performance.ch/
http://www.sqr.se/ (Handled by Automotion in the USA)
Please note that if you wish to tune your car whilst under manufacturers warranty the only tuner that will NOT invalidate your warranty are Hirsch, they are recognised by SAAB as an official tuner (similar to AMG/Mercedes or MSport/BMW)
As with all car tuning you should pay attention to the braking and handling of your car to cope with the additional power. You should also consider that failing to declare any modifications to your insurer could invalidate your insurance and potentially leave you open to prosecution.
DUMP VALVES AND BLOW OFF VALVES
A commonly asked question is "can i fit a blow off valve to my 9-5"? The answer is yes but it must be of the "recirculating" type. If you fit a DV that vents to air then the Trionic 7 engine management recognises it as an air leak and will reduce boost levels blunting performance. There is no discernable performance improvement from changing the standard Bosch fitment DV to either a Forge, Hyperboost etc. However what you are getting is a more reliable, serviceable unit with pistons that won't fail (unlike the diaphragm on the Bosch unit). Vehicles with a higher tune level will benefit from an aftermarket DV purely because they can hold more boost pressure and can be adjusted with springs/washers to suit different boost levels.
If you are after the pshhhhh sound associated with some turbo cars then ditching the standard airbox for an aftermarket air filter is the way to go. Just buy a "universal" style cone or cylinder filter with a 3" inlet and fit with a small length of 3" inlet tubing. Fabricating a splash guard underneath the open air filter is recommended otherwise you run the risk of water getting in and hydrolocking the engine.
Look I know you are just busting for more power but you dont need those parts yet.
Save up for your ECU and the open air filter is you like the sound, then take it from there.
Many of us have bought these other parts and ended up wondering why :confused:
But I love your enthusiasm ;)
If you are desperate for one, get one for about £30 from a breakers yard (the aero one that is).
When I got to stage 3 with my old LPT turbo, you could hear the turbo sucking the air through the old cobra, changed it to the aero one and the noise subsided, can't recall there being any difference in power though although my tuner said there would be (and I rather liked that noise!)
P
Once the big intake becomes relevant, you might want to consider the '06 Aero intakepipe aka kingcobra. Modified or '06 turbohousing is needed though.
For the picture I have added a Maptun intake (left) and the pre'06 Aero intake (right) to compare.
1 - 8 of 8 Posts
