1 - 11 of 11 Posts
Today, I was going through my trunk full of stuff for my ongoing repairs on my 9-5, picked up a "CRC throttle body cleaner" and started reading the can.....:eek:.....:x..Sh*t! "not for use on cars with superchargers, turbochargers...." I was in a hurry and grabbed alotta stuff outta pep boys and didn't bother reading the cans. So I ask you, Saabers, which cleaner do you recommend? Your recommendations would be much appreciated. Thanks.
I don't bother taking the TB off; that's what'e good about gumout it desolves all that crap that's in the intake as well; once the TB is cleaned I spray the gumout down in the chamber while the car is running; you might get a little smoke it's just the chambers being cleaned out.
+1 on this.
I usually have someone sit in the car while I spray into TB revving it to loosen up the butterfly valve, and get all the gunk out. You need to keep it revved a bit for a few minutes after the spraying to avoid it dying before the cleaner is through the system.
G
the instructions say to dry everything BEFORE starting the car, reason for this is there is alcohal in the cleaner and alcohal will damage catalytic converters.
Discussion Starter · #11 ·
......then start up the car and spray the gumout, CRC, or N-Hexane in the TB?
1 - 11 of 11 Posts
