Hey guys,
So I want to try cloning some ECM’s due to an issue I have with an Orio-sourced ECM for my 2011 9-3 (for background on this part of the story, look here: https://www.saabcentral.com/forums/showthread.php?t=726946 )
Anyway I know that the Trionic CANFlasher + OBDLink SX or similar should be able to do this via the car’s OBD port. But, I want to do this off the car if possible to avoid multiple off and on cycling of the ECM plugs and generally just to avoid risk of causing some problem of any kind.
What I am wondering is whether there is a write-up or information on constructing a bench system. I believe what is needed are:
J1962 plug
Power supply
ECM plug
Wiring between ECM plug, power supply, and J1962 plug
Some kind of pass-through such as OBDLink SX
Laptop with CAN flasher software
I already have a good lab-grade 12-volt power supply (that can be adjusted from 1v-15v if higher voltage like 12.5v or whatever is needed), but I’m missing the wiring/pin location info for the ECM and J1962 plugs. Since I already have the most expensive part, a good power supply and a laptop, the other parts could be assembled for little $ if I can get an OEM ECM plug from a wrecked 9-3.
Anybody happen to have a wiring schematic for this setup somewhere?
J1962 plug
Power supply
ECM plug
