Check the tension on the main serpentine belt and the A/C compressor belt. My 9000 is a 1990 2.0 carlsson and I recently needed to re-tension the serp belt (I installed a new one a few weeks beforehand) as it was starting to squeal for a short while after starting when the alternator cut in and the voltage regulator caused it to put load on the belt.Hi,
My car makes squealing noise as if one of the belts was loose. It only happens for a minute or so, when the engine is cold though, so it's a bit hard to tell what's happening.
Any ideas ?
thanks,
tim.
Maybe it is caused by a loose drive belt and the load on start up. The alternator will be putting out lots of amps to replace the draw on the battery created by starting when cold, so the pulley could be slipping.Hi,
Any ideas ?
thanks,
tim.
If your car has a 2.3 engine it will have the later style of 'automatic' belt tensioner which shouldn't need any intervention except when replacing the serp belt.
Craig.
The automatic belt tensioner (#5) on the B234 engine is hydraulic, and it can leak and fail.Later SAABs use the serpentine belt to run all accessories. Only early 9000 have a separate V belt for the AC compressor.The serpentine belt is self tensioning I thought.
Mine did many years ago. But it was a slow leak. Serp. belt was squealing but may not have necessarily been solely due to the tensioner itself. Indie replaced tensioner, one other idler pulley and serp. belt all together since they were original. So I don't know what would have happened if the tensioner was allowed to keep leaking and fail in the end.Thanks very much!
So, what will happen, should a tensioner fail ?
I imagine the serpentine belt will eventually fail. In a worst case, if was to suddenly let go then you would lose your function of your alternator, water pump, a/c. Not a good thing!!So, what will happen, should a tensioner fail ?
It would be fairly catastrophic. Would one lose power steering and brakes too ?I imagine the serpentine belt will eventually fail. In a worst case, if was to suddenly let go then you would lose your function of your alternator, water pump, a/c. Not a good thing!!
Looks like it's not impossible neither. Do search "serpentine" in 9000 Workshoprawill said:But I imagine a sudden failure would be highly unlikely.
Lets see if those who know more disagree with me.
