I have a 2006 9-3 with the b207L engine (4 cyl 2.0T)
Does this engine have a barometric pressure sensor and/or a secondary air pump?
Reason I ask is a 2005 ECU was installed in this 2006 engine (and programmed) and immediately threw codes for these items, p2228 and p0410. I was told by a mechanic that the 2006 engine does not have those parts so when the 2005 ECU searches for them and doesn't find them, it decides that they are faulty, broken or missing, thus the codes. He said I needed a 2006 ECU properly programmed to eliminate the codes.
Anyone know if this is accurate? Is the problem really the ECU or do those parts need replacing. Thanks for the help.
