Anyone know whats up with this? Im doing a complete overhaul on a 2002 b205r block & the bearings its calling for are wider than the bearings that are in there. Everything is original inside this block. The exhisting bearings are 20mm wide but the apparent replacement bearings are 30mm wide. The ones that are in the block look like the ones in the scandix picture. The ones I purchased are in the other picture. Do you think the wider ones will work in there as long as the holes are lined up in the block? or am i screwed here?
215.9 KB
151.3 KB
