Does anyone know, why bad irregular idle in both cold and warm, but sometimes is a good idle? Cold once stifle and when run the second time no longer thirst and hot bad idle is all the time. (When i disconnected the battery engine works better and is a good idle, but not long.)
When my 95 started to exhibit irregular idle, it turned out to be a rotted vacuum line on the back or firewall side of the throttlebody way down near the limp home solenoid. You might want to check that connection on the throttlebody.
Which tube is it exactly?
Discussion Starter #6
With vacuum tubes I'm fine. I have this code and when clear code, engine works good
269658
