Codes p0651 p1312. 2003 saab 9-3 arc. 1312 refers to cylinder 1&2 misfire so I swapped coils off a parts car not sure they are good. Code is still there. Read an article that said ecu sends 5v to the tps and coil packs. So before I just swapped the tps I measured at the tps connector with ignition switch on, orange wire, car not running. Was getting fluctuating reading 2.8-4.5 roughly, it was sporadic. Started car did same reading but was 3-5.5 same thing very sporadic all over the place. I tried checking coil with battery off I got nothing near 5v on any pin. Had 11.7 on the one with red wire. Any help greatly appreciated
