Here is the scenario,
I get in my car this morning and start it up as usual.
I also had to turn on the rear defroster, no big deal.
I let it warm up for a few minutes and make my way out of the driveway to head for work. I notice about a mile into my drive the TCS OFF light was on, I look at the sid and there was no error. I push the TCS button but it does not turn off.
So I put in to the gas station, about 3 miles away from home now and stop the car and push the TCS again, nothing it still says TCS OFF.
So I turn off the car and wait a few seconds and turn it on again, the SID says checking then OK, so I start the car but it wont start. I can hear few off the relays an clicks and the car barely turns over, like the battery was almost dead.
SO I turn it off and wait a minute and try again, and the same thing happens.
Same symptoms as when you have a bad battery. So I get ready to call the tow company, a guy comes by to see if I need help. I explain to him what just happened and he says let me jump you and see if it will help. So we hook up the cables and BAM! started right up. No warning code from the SID, everything says OK, so now I am contemplating whether or not I should go to the garage or head to work and see what happens.
I get on the freeway and head for work, I will deal with this later in the day when the dealer is open. My commute is about 40 miles on the freeway to work, so when I arrive at work, I park in my space and turn off the car. I wait a minute and start the car to see if it will start, I turn the key, and it starts right up. I am miffed. What do you think? Bad battery, electrical ????????
Another question is, when I went to get a jump I notice the battery has a nipple on the side and it is hooked up to a black hose, what is that, a vent?
I have never seen that before on a battery, and if I buy a new battery and it doesn't have a fitting for the nipple and hose is that OK and do I just leave the hose and nipple dangling there next to the battery or do I need to get a special battery with a fitting for the hose and nipple.
