Seat Cushion, Rear seat
To remove
1 Tip up the seat cushions (both 60% and 40% sections)
2 Remove the circlips from the hinge pins,
3 Drive out the four pins from the hinges,
4 Lift out the seats.
Backrest, 40% Section
To remove
1 Detach the backrest from the seat-belt member and tip it forwards,
2 Undo the bracket at the hatch which opens into the luggage compartment,
3 Extract the backrest from the bracket at the hatch and withdraw the pivot pin at the wheel housing,
Backrest, 60 % Section
To remove
1 Remove the 40% section ~
2 Detach the backrest from the seat-belt member,
3 Tip the backrest forwards,
4 Remove the middle seat-belt anchorage to gain access to the right-hand backrest bracket,
5 Remove the backrest bracket to the right,
6 Extract the free end of the backrest and withdraw the pivot pin from the bracket at wheel housing,
7 Remove the fabric tensioner and lift out the backrest,
There pretty light, this is a one man job.
