For all 2.3L engines 1994 to 1998, which components may be interchanged between the turbo and N/A versions?
Block, pistons, head, valves, cams, rods, crank?
What gives the N/A engine higher compression?
Can I use an N/A block, crank (and possibly pistons) to replace those of a turbo?
Twinsen I just do not know. The oil pans are different on a 93 9000 turbo and a 93 NA. the compression ratios are different so the rods should be different. The crank could be the same and head casting itself might be the same. The cams are probably different for fuel intake all the intake system is different, so I do not know
b234
hi.it might be worthwhile getting one of the parts manuals off ebay-fairly cheap on cd- and do comparisons there.i have one, but my computer is windows 7 and the cd i have is only good for xp.never mind. love that car.cheers.
