Try ZZperformance in Grand Rapids. You can buy anLDK take off oil pan brand new for a good price, around 75.00 irrc; it will need a new correct LDK dipstick tube, I expect, but it holds 6.5 litres which is a nice advantage, and assuming the only cradle clearance issues are by the crankshaft front damper, it will fit fine. It also has a float sensor for low oil that would be useful if you hooked it up. The pans for the LK9 (207) Have the oil pickup and the windage tray in place so its bolt on and go...my suggestion. I use LDK oil pans for LSJ replacement pans, as the LSJ pans are no longer available
