My engine has been working ok so far, changed spark plugs and DIC about 2 months ago.
I was driving and i suddenly start losing power. I stop the car to see what's going on.
It seems the engine will stall when at idle - sometimes it try to increase RPM, sometimes it just stalls instantly.
If i start the car and hit the gas pedal immediately, it revs up nicely. I i keep it around 2k RPM, it stays there, engine sounds ok, sounds normal (no nasty sounds, although the RPM sometimes fluctuates a little).
So with the car standing still, i can keep the RPM steady, however, if i put it in gear (it's a manual), and slowly raise the clutch, it will instantly die down (even if it's a 5k RPM).
MAF has been cleaned a few months ago, new air filter, new BPC valve, new serpentine belt, new fluids, the car was running absolutely fine until now.
What should i look for?
