1 - 7 of 7 Posts
As title really guys ,
Going to be twin charging a b204
Parts list sat in my workshop
B204 (obviously)
Hx40
Eaton charger
3bar map sensor
Tubular manifold
Intercooler
Bypass valve (for when chargers is at full chat)
I'm going to be requiring a set of injectors and somone to map the ECU ( including setting the bypass to open at a certain pressure)
Anything else you gurus can recommend?
This is also going to be rwd
Sent from my SM-A105FN using Tapatalk
Will all be going through rx8 running gear and axles
B204 (obviously)
Hx40
Eaton charger
3bar map sensor
Tubular manifold
Intercooler
Sounds like a great project.
Get onto trionictuning.com and download T5 suite. Tune it yourself, the T5 ecu has spare analog inputs you can wire the wideband O2 sensor to and with a cheap CANbus connector you can log all your data.
Cheers,
David.
Sent from my iPhone using Tapatalk
It’s been done many times before on various platforms. With varying degrees of success. Most of the results are “ mixed”. Polite way of saying useless. Volvo iirc recently had a twin charged model for sale The best guys for information ( email best and you may not get all the info you wish , these guys are a business) on twincharging are ZZPerformance. Al McClure. They are not Saab experts per se, but they have built several twincharged cars in the ecotec platform iirc. Good luck.
Have I missed anything (except bov and a maf) and which do you think would run better?
1 - 7 of 7 Posts
