So my passenger side axle on my 07 9-3 6 speed snapped. I had a spare axle from 06 93 automatic. Parts looked similar and it did fit. Ran into a question while replacing the axle. Once you’re done putting axle in and tightening the axle nut. Should there be any play in the axle left or right. I noticed that I can grab the axle between the 2 boots and make it go in and out ( not coming out of the transmission or anything). My confusion is on if it’s supposed to do this or am I supposed to pull the axle towards the wheel hub and tighten it all the way .
Not interchangeable.
