1 - 2 of 2 Posts
I'm looking for ignition control module with keys, locks, ignition barrel, ignition barrel housing, and twice unit. I have found one that is out of an 1999 Saab og9-3 automatic transmission. The kit has everything. Would this be compatible with my manual transmission 1999 Saab og9-3 se if I have my original manual trans shifter housing and accessories which have already been removed from the car? Need to get back on the road! Any help on the matter is much appreciated! Thanks!
The TWICE is not aware of the transmission type. The ECU knows, but the TWICE doesn't.
Since you have a 1999, you can avoid the Tech II matching issue with the ECU (lucky you!).
1 - 2 of 2 Posts
