How does the power flush work? The method I've used is to change the fluid, drive for 30 minutes / miles and drain again. Properly speaking a third drain at a thousand miles or so later should happen but that seems like it wouldn't help that much.
The local Saab shop says every 50,000 miles or so?ProfZ said:I'd change the fluid, and filter, every 100k miles. You don't need to do it any more often than that, but check fluid level evrry time you do an engine oil change to make sure you don't run low.
Unlike what some say about a manual trans, changing the fluid in an automatic will not cause problems regardless of its age.
