I want to install my cd player but found out there are no harnesses available for saab cars. Just wondering if anyone had a color chart for the wires behind the stock deck so I can hardwire mine in. Thanks guys.
Brian
I found a chart in my 1993's user manual (audio section).
there's a post on that around here somewhere. try searching the site, you are bound to find a wiring diagram or code that describes the wiring. it's fairly straight forward. IIRC, the stereo actually latches into a sleeve in the dash, that sleeve holds the wiring. Your best bet is to cut the sleeve out and use those wires to splice in your aftermarket harness. i did that with my C900 Turbo and it worked great.
Good luck!
