1 - 7 of 7 Posts
Hi. My 2.0t 5 speed vert has 73k miles. Its at stage 2 and I have a handheld so I can bring it to stage 3. That would give me a 25hp and 15 pound feet of torque boost, so not huge. I'm trying to decide if it’s worth going to stage 3 given the following:
I would be willing to spend the money on a gs downpipe w/ race cat. I would not be willing to spend the money on an intercooler or a 3" cat back, Also, I would not want to have to replace the clutch because of stress caused by the tune. With that said, I'm a relatively tame driver. Never track or race. I will push it on back roads now and then, but not too often. I do take it over mountain passes and back 5 or so times a year. I live in the northwest. It can be in the 80's-100 in the summer, but most of the year it’s temperate. My suspension is already tweaked, and I have a short throw shifter so no reason to spend money there.
So . . . (1) Should I add the downpipe and go to stage 3, but don't do the intercooler or cat back; or
(2) Would it be worth adding the downpipe and staying at stage 2; in other words, would a little quicker spool up be worth about $675); or
(3) Leave well enough alone? Thanks for your thoughts.
Why not ask BCB for their opinion?
If you’re worried about having to replace the clutch, then don’t modify the car. So, option 3.
You'll need an intercooler whether you want it or not.
Sounds like you made up your mind tbh. Don't need us to validate your choice.
Sent from my ONEPLUS A5010 using Tapatalk
Discussion Starter #6
The gs website says I only need a stage 3 tune with the downpipe. Diggs said I need the intercooler also. I suspected that, but wasn’t sure because I generally don’t run the car hard. I appreciate Diggs response.
I have no clue as whether the 3” downpipe with the stage 2 tune provides noticeable benefits and is worth the cost. I would appreciate everyone’s thoughts on that question. Thanks
Your stage 2 software has to be compatible with the 3" downpipe
1 - 7 of 7 Posts
