Hi folks,
I picked up a 1999 SE vert a couple if weeks ago. There's no sound coming from the door speakers so obviously a problem with the amp. I stripped it out of the car and checked the fuse inside, which was fine.
Next, I checked the DIN lead to see if there was a feed going to the amp when the radio was switched on, which there was.....
Next I checked the power to the amp. And there is none, whether the radio is on or off. Bugger. :(
Checked fuse 24 and that's fine too.
Does the amp go through a different fuse? If so, which one?
Where does it ground to?
Any other ideas?
Thanks folks!
