98 V6 2.5L NG 900S, on starting, displays what appears to be rapidly cycling power-loss to the electronics. When it catches, all is fine. I recall that I had similar symptoms when I flattened the battery once, but I've charged this one up full as a tick. It MAY be better when warm, but I'm not certain of that-(I don't get to drive it that often) Might this be a sign of the ECU "playing up", or do they normally just die straight out?
Welcome to saab central, when you say a power loss in the electronics, do you mean only the interior electronics, or does the engine also have some acting up issues?
The dashboard electronics are the most noticable; they go crazy, flicking on and off, and the starting appears to follow that interrupted power symptom as well, but strangely, I can't say if it's the starter motor power cutting in and out, or the ignition. I think it's the ignition that goes missing.
Thanks for your help, it's HUGELY appreciated.
Bill
Bill
My vote is on the ignition switch itself.
Sorry, can't go into more details!
_bny
thanks,,, I'll check that out. It WAS the last thing I touched when I had a prob getting the key to release. Maybe I didn't get everything back exactly right.
Hmmm, check out the ignition. You may want to make sure the battery is in good condition as well, I know it's almost too obvious, but sometimes thats all it is.
